推荐星级:
- 1
- 2
- 3
- 4
- 5
AP6xxx 参考电路设计
资料介绍
AP6xxx参考电路设计
AP6xxx评估板
规格书
部分文件列表
文件名 | 大小 |
AP6xxx_Pin2Pin_Reference_Design_Circuit_For_Q42142951.pdf | 316K |
部分页面预览
(完整内容请下载后查看)A
B
C
D
E
VDD_1V8
AP6xxx Pin2Pin Reference Design Circuit
R23
0R
CLK_REQ
When using AP6212A, R23 placement, R22/C18 NC.
Connected to HOST I/O 1V8
R22
C18
0R/NP
VDD_1V8
When using AP6476, R22/23 placement, R23 NC.
SDIO_CMD
SDIO_D0
4.7uF/NP
SDIO_D1
SDIO_D2
When using AP6181/ AP6210/ AP6212/ AP6330/
AP6335/ AP6255, R23/R22/C18 NC, pin5,pin8 floating.
WiFi ANT
SDIO_D3
(VBAT range3.0V~4.8V, 400 mA norminal,
450~850 mA maximum)
WLAN
VBAT
SDIO_CLK
WL_HOST_WAKE
WL_REG_ON
CLK_REQ
R6
0R
C1
AP6234 PIN5 &PIN8 for LTE COEX. If you don't use, you can floating.
C2
NP
4.7uF
C3
10pF
FM RX reference circuit
R80
R81
10K
10K
R71
FB1
VDD_1V8
50 Ohm RF trace
FM_ANT
BT_HOST_WAKE
BT_WAKE
BT_GPS_RST_N
75R-BEAD
0R
FB2
UART_TXD
UART_RXD
UART_CTS_N
UART_RTS_N
PCM_CLK
PCM_SYNC
PCM_IN
PCM_OUT
HOST_UART_RXD
HOST_UART_TXD
U1
AP6xxx
HOST_UART_RTS_N
HOST_UART_CTS_N
HOST_PCM_CLK
HOST_PCM_SYNC
HOST_PCM_OUT
HOST_PCM_IN
1.8K-BEAD
R82
BT/FM
AUDIO OUT
C24
1uF
J1
10K/NC
AUD_R
AUDIO_JACK
46
45
C23
1uF
N_VDDSWP_IN
N_VDDSWP_OUT
N_VDDSWPIO
IN/OUT must be cross
AUD_L
14
15
16
17
18
19
20
21
22
WL_REG_ON
WL_HOST_WAKE
SDIO_D2
WL_REG_ON
WL_HOST_WAKE
SDIO_DATA_2
SDIO_DATA_3
SDIO_DATA_CMD
SDIO_DATA_CLK
SDIO_DATA_0
SDIO_DATA_1
GND
44
43
42
41
40
39
38
37
36
35
34
UART_CTS_N
UART_RXD
UART_TXD
UART_CTS_N
UART_RXD
UART_TXD
UART_RTS_N
TX1
SDIO_D3
Trace width minimum >12mil
SDIO_CMD
SDIO_CLK
SDIO_D0
UART_RTS_N
TX2
SDIO_D1
N_REG_PU
N_I2C_SCL
GND
N_I2C_SDA
BT_RST_N
VIN_LDO_OUT
VDDIO
EXTLNA_EN
R79
0R/NP
VDD_1V8
BT_GPS_RST_N
When using AP6476/AP6251, R79 placement
C15
4.7uF
32.768KHz
S_CLOCK
Power Inductor
L3
Rated Current 1A
4.7uH
GPS ANT
32.768KHz
C16
4.7uF
U8
C27
RFOUT
ENABLE
VCC
GND
GND
RFIN
L5
C28
EXTLNA_EN
VDD_1V8
10pF
6.8nH
470pF
1. Using AP6181/AP6212A/AP6330/AP6234,
RL1/RL2 NC,
C25
33nF
MAX2659/BGU7005
RL1
RL2
R59
VDD_1V8
2. Using AP6210/AP6476,
RL1 placement, RL2 NC,
0R/NP
MCLK_IN
R77
3. Using AP6335, RL1 NC,
PL2 Placement for SDIO3.0
(VIO must be 1.8V)
Frame A
0R/NP
R13
0R
U7
NL27WZU04 (SOT-363)
MCLK_IN
OUT Y1
Vcc
IN A1
GND
IN A2
Using AP6210, Frame A & Frame B placement,
R47/R48 and Frame C NC and connect to module pin 30
VDD_1V8
4. Using AP6255, RL1/RL2 no placement,
default =1.8V
for SDIO3.0,
OUT Y2
R10
560K
RL2 placement for SDIO 2.0
Using AP6181/AP6212(A)/AP6330/AP6335/AP6255/AP6234,
Frame B Placement,
VDD_1V8
Frame C
R47
R48
FrameA & Frame C NC
and connect to module pin 10,11
XTAL_IN
XTAL_OUT
X2
0R/NP
0R/NP
TCXO 26MHz (2520)
Y3
26MHz (3225)
R12
C22
1uF
R72
0R
100R
VCC GND
MCLK_IN
OUT GND
Using AP6234/AP6255/AP6335,
Y3 change to 37.4MHz.
C11
C9
27pF
27pF
Using AP6476/AP6251, Frame A& Frame B NC.
Connect to module's pin 30.
Frame B
AP6476 AP6251 AP6452 AP6251U
AP6234 AP6255 AP6335 AP6256 AP6441
AP6181 AP6212 AP6330 AP6210 AP6236
Serial 12*12mm/LGA-44
A
B
C
D
全部评论(0)
